Transcoding Avi Files To Other Formats. Help!!
  • Transcoding Avi Files To Other Formats. Help!!
    Hi all.
    I am shooting a film in Taiwan and the production company is using Edius as it's NLE. We are shooting in 720/24p using the Panasonic HVX200. We are recording to a Citidisk rather than 24P. The codec that is recorded appears to be a Canopus codec 'CDVH'.
    How can I transcode these files into another format such as (mov) while not losing quality? I have tried Procoder but with no success. It is terribly hard to communicate here and I am not familiar with Edius and their version is in Chinese. We have shot 4 scenes using this codec which must be change as my home system is Final Cut which I must finish editing in.
    Any help in converting these files would be very much appreciated. Thank you.
    CDVH is the Canopus HD codec (DVCPRO HD compliant).
    Please note - do not load "codec pack" that you may be led to. They are cracked, may not function properly, and often contain adware/spyware and/or virus!
    You cannot legitimately get the Canopus HD codec without having EDIUS software. It's a licensing thing.
    Anyway, to get the HD footage from EDIUS to your Final Cut Pro system...
    Probably the easiest way is to output as QuickTime in HD resolution, in a codec that FCP understands. Note that you cannot export DVCPRO HD QuickTime files from Windows, in EDIUS or not. Seems nobody can do that right now.
    Good luck!
      it is amazing how many different digital formats there are now worldwide and once again, footage sharing has become a problem
      it was easy at first with DV tape, my DSR-25 plays Pal DV/DVCAM and NTSC
      now, I need 1/2 million dollars worth of different devices to be able to handle all formats
