24p and 23.98p
  • 24p and 23.98p
    Edius does not have a 24p option, just 23.98. I shoot some things with a GH4 in the C4K mode which does 24p at 1.85 (while the UHD mode does 23.98 at 16:9).
    So I'm wondering, when I drop 24p into a 23.98 timeline, does it stay 24p or convert to 23.98? Everything looks fine. I may be doing some DCP conversions in the near future and the difference then, if there is one, can be a problem. I'd appreciate any feedback. Thanks.
    Why don't you modify a preset & set it to 24p?
    Projects in Edius can be set to 24p fps if you create a new one.
    Andreas
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      You can create a custom preset with 24p. When you create one, go to the Advanced tab and set the Frame Rate to 24.
        Andreas
        Edius 8 - trying to change project settings frame rate and it's ghosted out.
        Can't change it to anything. Hmmmmm... I know I've done this before.
        Stumped?
          You can't change the frame rate on an existing project, only when setting up a new project.
            Thanks for the quick help!
