WG8 and Mask
  • WG8 and Mask
    Installed v8.1 (WG) and all seemed OK. Tried to use the MASK effect and it comes up as expected, I draw the mask and select 3 way colour corrector, all OK so far, but when I try to use the filter in the mask, nothing happens, I tried different filters and none has any effect in the MASK. I have used this before in v7.5 without any problems, so what is different in v8.1 that I can do nothing with it? I must be doing something wrong I assume.
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
    Did you go to the Function Box and check the first 2 options Apply Mask and Bakground?
      that seems to work here, see attached
        Is the mask tick box checked?
          Followed all your advice and now all works as expected. Thank you all for that input, it is greatly appreciated.
          RAM 32 GB.
          ASUS P9X79-Deluxe.
          PS Thermaltake 1kW.
