This probably has been asked before but I couldn't find a direct answer, I currently have edius 8WG installed on my pc. I have bhought a new pc now and want to use edius 8WG on that one as well and have the old pc as backup, am I allowed to do this and if so, will the activation process be succesfull as there allready is one version registered under my name? Is there anything I should consider in this case?
Using edius 8 wg on 2 pc's
Yes thats all OK.
The only restriction is: You must not use both Edius-Installations in parallel.
Regards kurtHW: ASUS Z170-A; Proz: i7-6700K; RAM: 32 GB DDR4; GPU: RTX-3070, 8GB GDDR5; SSD: SAMSUNG-850-Pro, 500 GB
SW: WIN-10/64 PRO (22H2-19045-2364), Firefox u.a.
NLE: EDIUS-X(10.34.10198)-WG; RESOLVE-18.1.4.0009 Studio
// Read > Test > Understand
How many installations are allowed?
I have three systems: Work Desktop, Home Desktop, Laptop.
I don't need to use more than one system at the same time.
Can I install Edius 7.5 on all of these?
When I will change/update one of them (changing system harddrive, for example) I need to deactivate it, right?Edius 8.5
Desktop: Asus X99-E WS USB3.1 - Intel i7 6800K - 32Gb RAM
Notebook: Asus N56V - Intel i7 3630QM 2.4 GHz - 16GB RAM
KurtHW: ASUS Z170-A; Proz: i7-6700K; RAM: 32 GB DDR4; GPU: RTX-3070, 8GB GDDR5; SSD: SAMSUNG-850-Pro, 500 GB
