Converting PAL avi to NTSC
  • Converting PAL avi to NTSC
    Hi, I have a project that has been edited in Edius 4.5c PAL and I need to convert it to NTSC for authoring to a dvd for the USA market. I'm having problems with the encoding from the timeline in that whatever I do the audio at the end (a 90 minute video) is out of sync by about half a second.
    I have tried exporting a PAL avi (which is ok) then using Procoder to convert to NTSC but the same problem exists.
    Anyone had the same problem? Am I missing something?
    I have done this in the past (with Edius 3) and no problems.
    Pete
    Win XP, Edius 4.51c NX.
    Pete Silver
    Edius 7 Vistitle 2
    www.psilver.com
    Are you converting it from PAL avi to NTSC mpeg2 ? Or avi to avi?
      the only way to overcome this is by exporting to avi
      then use Tmpeg 4 Xpress to convert to NTSC elementary or program stream using ac3 audio at 256kbps or less, no audio drift at all
      I do this on a regular basis and have also found that on a 60 min project, ProCoder3 causes lip sync to gradually drift by 10 frames by the end of 60 min
      also, ProCoder3 causes strange motion artefacts
        Tried both, I'll try Anton's method.
        Pete
        Pete Silver
        Edius 7 Vistitle 2
        www.psilver.com
          I was using Procoder Express so the same with that as well.
          Pete
          Pete Silver
          Edius 7 Vistitle 2
          www.psilver.com
            Pete
            Antons method converts from PAL avi to NTSC avi, then from there to Mpeg. Thats were I was going :)
              no, Tmpeg can convert from Pal avi direct to NTSC mpeg
