Hi all, (still on EDIUS 3.6 for the moment).
Does EDIUS 4.5x have the capability to convert NTSC SD to PAL SD? Whenever I try to change the Project Settings (I'm looking at the "trial" 4.5 version) there are no specs there to change to. I would surmise the footage would probably have to come in as PAL to switch PAL settings - is that correct? If so - do any of the ProCoder versions (Express or 2 or 3) convert? If not, does anyone know of a program that makes that conversion, for I have some European orders for PAL DVD's.
Many thanks,
Alan
Many thanks,
Alan
