Source browser and DVD player not working together . . . can't get the browser to import the files on the DVD.
D V D source browser problems
How are you doing it?1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
Originally posted by Chismoso View PostSource browser and DVD player not working together . . . can't get the browser to import the files on the DVD.
you need a DVD burner to add and transfer to bin
if the DVD was made with a standalone DVD Recorder, it will fail in EDIUSAnton Strauss
I need to bring a file in from a DVD (original material edited in EDIUS, and DVD compiled with Encore) so that I can use it as a reference when repairing a later version of the timeline that has got corrupted — I intend to use it temporarily P-in-P so that I can match the material and edit points.
I've selected the material in the Source Browser, and Added it to the Bin — the M2P file is shown in its properties as 3.62GB, but the duration in the bin is only 1 frame, and apparently can't be lengthened. Where did the rest of it go, and how do I access it all?
Regards, GRAEMEGRAEME ALDOUS
Teeafit Sound & Vision
Yorkshire
this is caused by the fact that you are using a version later Than EDIUS6 where reconstruct files has been removed in settings
in later versions of EDIUS, you can play with the following settings, try as seen in attached and see if it works, and if the setting is already on, turn it off and try
if it still fails, use TMW5 source wizard, it always works
or use PgcDemux (free) to demux the DVD to elementary streams, it always worksAttached FilesAnton Strauss
Originally posted by Teeafit View PostI've selected the material in the Source Browser, and Added it to the Bin — the M2P file is shown in its properties as 3.62GB, but the duration in the bin is only 1 frame, and apparently can't be lengthened. Where did the rest of it go, and how do I access it all?
Regards, GRAEME
Have had the same problem, worked on my laptop but not on my main system
Since changing to Windows 10 it now works on both, no guarantee that will help but all came good here after upgrading
Originally posted by antonsvideo View Postuse TMW5 source wizard, it always works
Many thanks — I tried changing the settings, but no joy. So I Googled 'TMW5 source wizard'... and got this forum page!
Originally posted by antonsvideo View Postor use PgcDemux (free) to demux the DVD to elementary streams, it always works
Barry — thanks, too, but I'm loath to try W10 yet!
Regards, GRAEME.GRAEME ALDOUS
Yorkshire
I forgot to mention that you need to close EDIUS after making the change and delete the Transferred folder
if this folder is not deleted, the source browser will not replace what is already there
then start EDIUS and retransfer the DVD, it should work with the opposite setting of what it was, can you confirm what yours was set to?
sorry, TMW5 is no longer available and TMW6 has a yucky interface, all faded items with blue highlights
here is how it works in TMW5
and here you can buy TMW6
Originally posted by antonsvideo View PostI forgot to mention that you need to close EDIUS after making the change and delete the Transferred folder
Yorkshire
No, sorry Anton — whichever setting I use, the disc reads away for ages in the disc burner (it's a 1-hour track I'm trying to import), but when it finally arrives in the bin it's only 1 frame long.
With either setting it appears in the Transferred folder of Explorer as a 3GB m2p file, but if I drag it into the bin the result is the same. M2p won't play in Windows Media Player, so I can't tell if it's been ripped from the disc OK, but the size of the file suggests it has.
As I may have said, it's no big deal in this case because I'm only using it for a reference (and could capture it through a link from a player if I needed), but if for some reason I'd needed to import in best quality to incorporate in a project, then I'd be in a pickle.
A shame — if anyone has an alternative answer I'm willing to give it a try.
Yorkshire
in that case you need to either revert to EDIUS6.08 or use other means like PGC DemuxAnton Strauss
