7.5 install problem, activations question
  • 7.5 install problem, activations question
    I may have made a mistake loading a "User Manual" before downloading Edius 7.5_.0191_Updater.exe FULL INSTALLER. I fear this may be causing some problems. I try to install the UPDATER to the full install and when I do this, I am taken to self extractor which says "Welcome to Edius UNINSTALLER wizard and I believe asks me to DEACTIVATE MY LICENCE. Is this normal? Am I LOSING one of my license activations? Is it better to UNINSTALL EVERYTHING and start over or does that also affect my number of activations?
    Edius 7.5. Windows 7 Home Premium 64Bit. Nvidia G Force 9400GT - 1 GB Video Memory. 8GB RAM. Direct X10. Intel CPU-DP35DP-Quad Core Intel64Family6Model23 Stepping10(2009build). Max Clock Speed 2666MHz. 1-240GB Sandisk SSD UltraII. 1-1TB - Seagate HardDrive ST310000333AS ATA. 1-2TB Seagate HD STBD2000101. 2-Panasonic AG HMC150 cameras.
    you have downloaded the wrong file
    the updater will not remove your previous version and will not ask you to deactivate
    the updater has a file size of 357MB
      I've installed the Full Install already. When I try the 357 updater it brings up uninstall wizard then wants me to deactivate. I am confused by this activation limit because I've been using the Dongle till now and do not want to waste an activation before ever using this product. Does uninstalling everything waste an activation license? I'm trying to get this right the first time because I had a lot of problems at the end of version 5.51. Thanks for a reply.
        what is the currently installed full version? It must be any version 7 otherwise the updater will remove your previous version
          License manager says version 7.
          Program says 7.5 when I open it.
          Manual that I downloaded that worries me (because I installed it prior to Full Install of 7.5) says Hardware Guide 7.41.
          This is why I am thinking of starting over.
            can you open EDIUS, help menu, version info and type the full version number here
            also, confirm the full name of the updater.exe
              I cannot open Edius Help Menu because I have not yet set up Edius. I only installed it. Both the Full Install and the 357MB Updater are # Edius 7.5_0191_Updater.exe which is shown on the GV Download page.
                what is the full name of the full installer you installed?
                the 191 updater is to be applied to older versions of EDIUS7 and not the full version of 191
                  EDIUS Software v7.50b0191 Full Installer Released: 2015-04-08
                  This EDIUS v7 installer package contains all the files necessary to fully install the software on a new system
                  EDIUS Software v7.50b0191 Update Released: 2015-04-15
                  This update contains feature improvements, bug fixes, and is an official localized version.
                  These have been copied from GV Download page.
                    ok, I need to ask the question, why would you want to update the full installer? it is already the same as the updater?
                    updaters are for full versions with a lower number than the updater
                      Their instructions told me I need to install the Full Version first then to install the updater after that. Much of this is new to me and it seems they could make it easier for novices. Can you answer the question about activations? I am concerned that I may have made a mistake by installing a previous Manual before downloading Full Install. Does it affect my permissible activations if I just uninstall everything and start over fresh? I prefer to do things properly the first time and not have to solve technical issues later. Thank you for all the time you spend helping people.
                        The manual has no effect on the installation.
                        You are currently running the latest official version.
                        Do not run the update at this moment.
                        Start Edius and enjoy. ......
                        Tony D.
                          uninstalling and choosing not to deactivate does no harm
                          uninstalling and choosing deactivate does no harm either, but you can only do it three times per month, if you exceed that you need to call support to reset the license counter
                            also provide info on where you were told to install 191 full and then update to the same version, because that is wrong info and needs to be removed
                              SoundFreak_HD
                              Thanks for your input. Is there a reason why they instruct you to do things a certain way when those instructions really do not matter? This should be a much simpler process as witnessed by all the questions that have been posed since they started this upgrade promotion. They really need to hire more competent writers. Then this forum would not be as cluttered as it is with questions such as mine.
