Do we have a Offline Editing in edisu 7??? help
  • Do we have a Offline Editing in edisu 7??? help
    Dear all,
    My computer is too slow but could we make Offline Editing in edius 7 ?
    if yes how could we make it ???
    thanks
    your computer is too slow for 4k? or HD? or SD?
      It is too it is slow when editing in HD ,
      and also when i use multicam edit in HD ?
        in that case, switch the project to SD while editing and when done, switch back to HD for your export
        make yourself an SD preset and then the switch only takes a second
        http://www.videoproductions.com.au/e...-switching.mp4
        and make yourself a keybord shortcut to project settings, in my case ~` key
          Already I have an SD project ?
          and this is happen only with high formats of HD and with multi cam ?
          Do you advise me to buy a new PC ?
          If yes help give a PC specifications that would be suitable for HD and 4k
          thanks
            thanks
            please see spec in my signature, it will do all with ease
            in any case, if you switch to SD during editing, your HD footage should edit fine, if not, then you really need a new PC
            if you go to EDIUS help menu and generate a system report and attach it here, I can see what you have now
