There is a problem with the audio line in edius 8.
You can't edit the in or out of a clip, you can't trim the audio clip.
It elementary thing that you need to have and work with.
In edius 7.5 it work fine.
The only way that you can trim the audio clip in the timeline
is in trim mode.
Can you fix it?
is in trim mode.
Can you fix it?
