Problem with MENU
  • Problem with MENU
    Hello
    Before I started working with Edius 7, I had been using Pinnacle Studio. Unfortunately Pinnacle Studio didn't accept MKF files so I had to change program.
    In Pinnacle, there weren't any sequences. Everything was at the same editing line and that's why I have a big problem.
    My editing steps in Pinnacle (wedding films)
    1. Introducing clips and music
    2. Transition from the last clip to MENU (menu was visible on the editing line)
    for example, when the last scene was bouquet of flowers, I made transition to the same bouguet of flowers which was a background of the MENU
    In Pinnacle I was able to do MENU on my own and edit it
    IS IT POSSIBLE IN EDIUS? How can I make a MENU film?
    I can't imagine that I would not be able to edit MENU like I used to do it in Pinnacle.
    Please, help
    Thanks in advance ;)
    yes, you can change menu background, thumbnails and any text seen on the menu
    but you can't do complex things like chapter playlists and multiple audio selection or return to last menu with last used button highlighted
    DVD-Lab Pro is great for that and is all I use for DVD
      You're not going to be able to do a first play with a dissolve into the menu. You are going to need a full authoring package for that.
      I used to do that all the time with Encore.
        you can also make a motion menu with any video on any sequence
