Hi, I just wanted to bug report a small error in Edius 8.
I had a project that I wanted to make MPEG2 Elementary Stream files for DVD authoring. When I used the MPEG2 ES preset with default settings, it created strange random decoding problems (severe smearing and what looked like the worst macroblock decode errors I have ever seen) in Encore and on the DVD, (much worse in encore though) I then had a closer look at the default settings for the export preset and noticed the GOP size was at 15, which is the PAL standard, while NTSC should be 18. I changed the setting to 18 and re-exported, and my decode problems were gone.
I never checked through the other NTSC mpeg2 presets, so if you have to use them, take the time to check the settings
