Turn On Effects Multiple Clips
  • Turn On Effects Multiple Clips
    I had to break one clip in to multiple. If I turn off a slower effect, like Skin Touch Up, is there a way to highlight multiple clips and turn that feature on for all of the clips at once? Or should I only have the effects on the first clip, and try to copy and paste to the other clips all at once? It is the same exact effect.
    No can't see a method.
    Splitting a clip with say emboss filter added but unchecked or off, into 6 clips, there isn't a way of turning the unchecked into checked by selecting all apart from as you say coppying it to all the others from the "master Clip"
