Edius6 - AC3 audio waveforms deseperately flat
  • Edius6 - AC3 audio waveforms deseperately flat
    I'm still working with Edius 6!
    I used to edit AVI sequences with PCM audio. I just changed my camera and I had to switch to AVCHD with AC3 audio. Unhappilly audio waveforms on time line remain flat! AC3 codec has been reinstalled and successful installation is confirmed in the windows media codec list. WMP works fine with "AVCHD + AC3" footage, but audio time line in Edius remains desesperately flat
    What's going wrong?
    Thanks for your help.
    Vincent
    Are you getting audio and no waveforms, or no audio at all?
      try resetting waveform in properties...sorry if this may not be the correct place to do it...away from my edit system for some days...
      Hudson Valley, NY
      i7 8700K @ 3.70 Ghz/16 gb RAM
      windows 10
      284 gb SSD boot drive
      2 TB work disc
      2TB storage disc
      EDIUS 9.52.6031
        add the normalize clip tool to the timeline tool buttons
        select the clip and click the tool, done, if still too low, change the value in the normalize tool until happy
          Thanks Tobe and Anton.
          Tried it all out.
          Quick Time also reinstalled; And nothing changed
          What can I do more?
          Vincent
            Log view can help in that situation.
            User settings > timeline bottom right hand side of window audio linear or log.
              You never answered my question...
                what was your question Pat? and who did you ask?
                  Post #2 for OP...
                    oops, I looked and did not see it :)
                      Sorry Pat,
                      I was away for a few days on a business trip!!
                      I am getting no audio and no waveform at all in Edius....but clip works fine in WMP!
                      Vincent
