[8Pro] oddities with effect pallette
  • [8Pro] oddities with effect pallette
    I don't know if this is my setup but effect drag & drop onto folder of the effects palette no longer works.
    Is it the same for you ?
    E8W
    Desktop: Seven Ultimate | P8Z68-vPro 16GB | [email protected] | GTX560Ti | FW410 | U2711 | SDM205k | Shuttle Pro
    Misc: HVR-A1 | GH2
    Is the key-symbol at top CLOSED ??
    Intel core i7-6700K / ASUS Z170A / 32 GB RAM / Intel HD Graphics 530 / SSD Systemdrive / Gigabyte GeForce GT 1070 / Win-10/64 Pro / EDIUS-X(10.32.8750)-WG / Mercalli (V2, V4 and V5 Plugin/64bit) / RESOLVE-18 Beta-3 Studio / ImgBurn / PowerDVD etc.
    // Read > Test > Understand
      Thanks, this is a good point.
      It works when the key-lock is in LOCKED position. My logic was it should do the opposite, I mean you can touch and re-arrange the effect palette when it is UNLOCKED ...
      From user manual, page 350:
      Folder Structure of [Effect] Palette
      You can sort effects or folders, or change the folder structure. Or you can lock them not to move by mistake.
      Fixing Folder Structure
      1) Click [lock] in the [Effect] palette.
      Each click on [lock] switches the lock on and off.
      Note
      When you select [Return to Default], the settings return to the default even after [lock] is enabled.
      “Initializing [Effect] Palette” (w page 351)
      Changing Folder Structure
      Before making an operation, click [lock] to disable the lock.
      Is my english understanding so wrong or it is a v8 bug ? (I don't remember how I did with v7...)
      E8W
      Misc: HVR-A1 | GH2
        I should have written as an addition to my tip that the Lock-Symbol works wrong. It is a (known) bug!
        Until the next correction we have to think "inverse" :-((
        regards kurt
          So my brain is still working accurately :)
          thank you for the hints kurt.
          E8W
          Misc: HVR-A1 | GH2
            it is a bug that is reported
              Looks like this bug is present in every new upgrade, 6 or 7 also had this, not ?
              Tony D.
                no, this is a brand new bug only available in 8
                  If I have the time I will go and dig.
                  This issue has surfaced a few years ago with the reversed padlock on the effect pallette, I'm sure as I am sober now :)
                  Tony D.
                    This will be fixed in an update very soon.
