Attached are two snapshots of a file made by the JVC 600. Last week I update the firmware from 3.06 to 4.0 for the camera. A strange phenomenon is occurring during playback on the Edius timeline. The video appears to be very jumpy but the audio is fine. Brought into premiere pro and all seemed fine. WMP plays fine. It only appears in Edius. Can anyone explain this?
JVC 600 and Edius
JVC 600 and Edius
Thanks,
Ara
Windows 10 Home 64 Bit, Edius WG 9.55.7303, Edius X WG 10.20.7490 Intel Z370X Motherboard, i7-8700K 4.7 GHz 6 core, 12 Thread LGA-1151 CPU, GTX-1080 8GB Graphics card, 500GB M.2 PCIe NVM SSD, 16 TB Raid 0 Media Drive, 32 GB DDR4 Memory, Intensity Pro 4K AV I/O, CS 5.51 Production Suite.Tags: None
what is your EDIUS project setting? can you provide a screenshot with advanced expandedAnton Strauss
Anton. Attached is a screenshot of my project settings however files created in the camera before the new firmware update playback perfect.Attached FilesThanks,
Ara
your camera files are upper field
your project setting is lower field, can you try upper and see if that helpsAnton Strauss
Tried upper, lower and progressive all yielding the same result. I have attached media info on a file created by the camera just before the firmware update and all looks the same. I can only conclude that the firmware corrupted something? Could the flash band correction have something to do with it. In the menu it is on.Attached FilesThanks,
Ara
Have you got any shortish clip you can upload somewhere and give us a link?
MikeSys4: Z10PE-D16WS MB 2xE5-2696 Xeon 72 active logical cores. EWG9. 64G RAM. Aorus GTX1080Ti. 55" Q7 1500 NIT HDR 4K TV/Storm 3G Elite/Decklink 4K 12G/8CH audio monitoring, Yamaha RXA-870 A/V. Sys1-3 EWG8 + RX-E1+HDBX1000 MIP in HP xw8600 2 x X5492 CPU 8 cores, 8Gig RAM, Quadro FX3800. All sys Fibre to central media pool - 5TB Axus Yotta RAID + QLogic Fibre Switch. Central VCR rack plus YUV & audio to viewing room with Yamaha AX1 7.1 100 watt per channel amp with 1000W sub 63" HD 3D Samsung TV
Just got off the phone with JVC and firmware 4.0 seems to have issues with the field order in older versions of Edius. The problems are only with SD files and there is no fix at this time. Anyone else experience the same issue?Thanks,
Ara
Originally posted by ajcvideo View PostJust got off the phone with JVC and firmware 4.0 seems to have issues with the field order in older versions of Edius. The problems are only with SD files and there is no fix at this time. Anyone else experience the same issue?
Try right click the file on the time line click properties and charge the field order on that file in there and hit play.JoiCam´s
And more
Originally posted by johannesj View PostTry right click the file on the time line click properties and charge the field order on that file in there and hit play.Anton Strauss
Originally posted by ajcvideo View PostJust got off the phone with JVC and firmware 4.0 seems to have issues with the field order in older versions of Edius. The problems are only with SD files and there is no fix at this time. Anyone else experience the same issue?Thanks,
Ara
3 people have suggested you change the field order of the clip (which would be the first thing to check when a clip is shimmeing/jumpy) - never mind what JVC tell you have you tried what was suggested here? As Anton says it can be fixed in ONE Mouse click. I cannot believe if the clips plays in PPro it cannot be made to play in Edius.
With all due respect if you read the entire thread you would have seen that it was tried and failed. As far as JVC is concerned that is what the person stated to me on the phone. They have gotten several calls from Edius users.Thanks,
Ara
I had followed the entire thread and it was by no means clear if you had tried swapping fields and project settings in various combinations. Additionally it was suggested by Mike you upload a clip, I don't see that either with all due respect.Last edited by DigitalDave; 08-04-2015, 05:04 PM.
Originally posted by ajcvideo View PostTried upper, lower and progressive all yielding the same result. I have attached media info on a file created by the camera just before the firmware update and all looks the same. I can only conclude that the firmware corrupted something? Could the flash band correction have something to do with it. In the menu it is on.Thanks,
Ara
ajcvideo
The reason for why you should change the field order in the file by using right click and properties has to do with wrong information on the field order in the file.
So by changing it to the right field order in the file gives Edius the right info to play the file the right way.
And as Anton mentioned, it is so easy to do all of them at the same time with just one click.
Just try one and then change the rest when you find the right field.JoiCam´s
And more
