You can export a CSV file from the timeline in the marker Window. However, Encore does not have a chapter import option so its no use. I still export the CSV, then have it open next to Encore, type in the timecode into Encore and then press * to add a chapter.
EDIUS silver certified trainer. Main edit laptop: DVC Kaby Lake desktop processor laptop, 32GB RAM, 3.5Ghz i5 desktop processor, nVidia 1060, Windows 10. Desktop: 4Ghz 9900K processor, 32GB RAM, nVidia 1660TI GPU, Windows 10. Desktop: 2Ghz 12 core Xeon processor, 32GB RAM, nVidia 1060, BM Intensity Pro, Windows 10
I do all of the chapter points manually in Encore. It is fairly quick and painless. If it doesn't matter where they are placed, there is an auto add function that spaces them by time.
Six Gill DV www.sgdvtutorials.com If you own the Tutorials and you need help, PM me.
The exporter works great...with Authoring Works. Encore does not have any way to import chapter markers.
This and the 'no changing progressive timelines to DVD timelines in Edius' design have been a huge thorn in my side because DVD will never die!
Asus Prime X299-A-Intel i9 7900x all cores @4.3GHz 2 cores @4.5GHz - 32GB RAM - NVidia GTX1070 - Edius 9 WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 10
Both tools are transfering EDIUS Sequence marker into Encore chapter marker
Eric
English is not my native language
___________________________________ System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30 System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
Thanks for posting Eric. I was familiar with the Macro Generator using subtitles, but have not seen the other method by Michael Schleider.
Do you have any information as I can not find any mention of this utility on the Edius training video website you linked to.
unfortunately there are no further information published.
The tool is a bonus of the EDIUS Training DVD and not mentioned on the cover or webside.
I'm using it frequently and it works perfect for me.
1. export the marker list as a CSV.file
2. open Encore projekt
3. start Encore Chapter Converter and load csv.file
Thanks for your follow up Eric. I will contact Gavin Lucas and see if there is a way to have the marker tool separated on its own for purchase.
Looks a lot better than the subtitle approach imho.
Sure. If I learn anything I will post it in the lounge.
