Best worflow converting HD project to SD dvd w/ edius 6.55
  • Best worflow converting HD project to SD dvd w/ edius 6.55
    Shot a wedding with Canon T3i and edited everything in HD timeline. I'm going to be putting it in a DVD using Edius dvd authoring. So i'm just wondering what the best workflow in getting my HD project to into an SD DvD. Thanks in advance..
    Edius System- Windows 7 pro Sp1, Intel i5 760, 16gb ram, NVidia GT240..
    Set your project to SD with Landzcos 3 scalling, if your titles are in V or VA tracks everything should scale correctly
    IF you have used the "T" track check title sizing as it does not scale
    Regards Barry
      Note: if you used any layouter rotation in your HD project, do not switch to SD because the result will look out of focus (soft)
      instead, in project settings, set render codec to Lossless, them mark in at start of timeline and out at the end
      now press Shift+Q, this will render to Lossless HD and place on empty track above
      now switch project to SD with Lanczos3 enabled in the SD project settings and make your DVD
        Dont think i did.. So if I do this i can switch back to HD and still be able to burn a blu ray disc right?
          yes, it is just a simple switch back to HD
