Interview with mono mic: I need to listen the audio from two speakers
  • Interview with mono mic: I need to listen the audio from two speakers
    Hi, I have made an interview with a mono mic. Now when I listen that clip I listen that audio from one speaker only. Even if I put the same audio clip on the second Edius audio track, the audio goes out only from one speaker. I need to listen it from two speakers. But I need to modify only that clip and not all clips on the timeline. Is it possible?
    Thanks for your suggestion.
    CPU: Intel i9 7940X
    SSD Drive:
    If you want to just monitor on both speakers, open the audio mixer, look to the right of Master and click on the speaker with the arrow. Select Monaurel. You should hear everything on both speakers.
    To actually change it, use the Pan pot Balance effect and center the audio (I kerp this a a user preset).
      Import this preset into your effects palette and apply to your audio track.Dual Mono.zip
        Very useful your reply. THANKS
        CPU: Intel i9 7940X
        SSD Drive:
          if you are using a stereo track, right click, properties, audio tab, select mono1 or mono2 depending on which channel is the good sound, done
          using this method will keep the volume level
          using panpot filter will lower the volume
            I believe he said mono...
              ahhh, one of them mics with built in recorder?
              I assumed a mic plugged in to left or right channel of camera
                It was a mono Lavalier mic.
                CPU: Intel i9 7940X
                SSD Drive:
                  plugged in to what recording device?
                    Plugged into Sony AX1000 camera, the connection is for a mic.
                    CPU: Intel i9 7940X
                    SSD Drive:
                      was it plugged in to the left channel or right? or does the camera only have one channel?????
                        Mic was plugged by micro jack. Incorporate mic is stereo but I think it has one channel for external mick. I chose manual audio.
                        CPU: Intel i9 7940X
                        SSD Drive:
                          if you right click your clip and go to audio tab, is stereo, mono1 and mono2 grayed out, or can it be changed?
                          if grayed out, you have a pure mono track
                          if not grayed out, you have a stereo track with good sound one one channel and bad sound (or no sound) on the other
                          if so, click mono1 or mono2 depending on which has the good sound
