White balance
  • White balance
    I have some footage where the white balance is off. How do I get rid of YELOW?
    Theo
    Have you tried the 3 way color corrector?
      I was hoping that someone would have a magic potion an save me a lot of work. In so many words I was to lazy.
      Theo
        click the gray button and then click something that should be gray, such as a cloud, road etc
        Performing a White Balance on problem clips by using the EDIUS 3 way color correction filter
          Looking at the waveform monitor you may see that the disply is not centered.You can use the u&v in the YUV filter to nudge back into the center as another way of correcting the colour.
          Ron Evans
          Ron Evans
            You could try this free download from NewBlue:
            Color Fixer Pro by NewBlueFX is now 100% free and works in every professional NLE. Get the best free color grading plugin!
              You will have to find the tool that works best for you in that situation. All the correctors have their good and bad points. In the 3 way one the centre adjuster adds colour to a black and white image (ie one with the colour turned down) and sometimes you can fix yellow in a full colour image by adding some blue, but you have to look carefully to make sure nothing else goes an odd colour.
              You can also use the 3 way filter in selective colour mode (Hue) and select the colour you want to change from the slider, if the rest of the image is ok.
                i downloaded the newblue color corrector, but can't find it in EDIUS or as a stand alone. any clues as to how to get it working?
                Hudson Valley, NY
                i7 8700K @ 3.70 Ghz/16 gb RAM
                windows 10
                284 gb SSD boot drive
                2 TB work disc
                2TB storage disc
                EDIUS 9.52.6031
                  You did it also install after download?
                  Then the NB-effect should be seen in the effect palette (under NewBlue...)
                  (I had no problem with the installation)
                  kurt
                  NLE: EDIUS-X(10.34.10198)-WG; RESOLVE-18.1.4.0009 Studio
                  // Read > Test > Understand
                    will check again later today...thanks for the pointer.
                    Hudson Valley, NY
                    windows 10
                    2 TB work disc
                    2TB storage disc
                    EDIUS 9.52.6031
                      Hi Tobe:
                      I have to correct me: I had installed NBcolorcorrector some times ago into E7.5 and from there the plugin copied into the E8-Pluginfolder (where it works).
                      When trying to install NBelements (trial) under E8 this didnt work and NB says it will need some weeks until a new NB-E8-Installer will be ready!
                      So it could be that the NBcolorcorrector falls under the same restriction .
                      Regards kurt
                        Maybe it's me...I downloaded, installed and tried to register...shows up as an effect but with cross hatch as if it were a trial...will try again and if not, reach out to New Blue. I though it was a free app...maybe not?
                        Thanks for the comments...this is on an E7 system.
                        Hudson Valley, NY
                        windows 10
                        2 TB work disc
                        2TB storage disc
                        EDIUS 9.52.6031
                          I think if you color correct the tools in EDIUS are better. They work in 10 bit while the New Blue plug-ins only work at 8-bit in EDIUS.
                          If your acquisition is 10-bit it makes more sense to stay in 10 or grade in a higher color depth. Even 8 bit footage will benefit in a 10-bit grade.
                          But feel free to use the NB color corrector. Just added a piece of info which can be important to some. :)
                            White balance
                            Sorry for not responding sooner. I did not think that anyone would respond since I admitted being lazy. Thank you Anton. Clicking Grey works miracles.
                            I almost delivered the project with bad colors. Thanks to everyone for your advice. Just shows me that I have so much more to learn.
                            Theo
                              I always filmed a 5 seconds (right in the beginning of any recording) my Spyder CheckR 24 card - as a matter of habit. Never had an issue with colour correction again.
