Edius 7.5 will not load AVC file by Yuneec ST10
  • Edius 7.5 will not load AVC file by Yuneec ST10
    I have 7.5 loaded in my laptop and have been trying to get the hang of it before I use it for my main edit system, so maybe I missed something.
    I can not get AVC files to load into Edius. The AVC file are low res files recorded on the ST10+ controller, made by Yuneec.com. They make drones. I can play the AVC file with powerDVD loaded in my laptop with Windows 7.
    Do I need to add a codax (spelling)? I thought that Edius could "Edit Anything", but I guess not these AVC files.
    Any ideas?
    Bob
    AsRock Z170 Extreme6+, I7-6700K OC to 4.7, MSI GTX 980ti, 32gig of ram, H100i cooler, 1TB WD Black for system. WD Black drives For footage, Sizes changes as needed. 2 WD Gold drives are in a Raid setup, Win-10 Pro 64bit. Edius 7.53
    2 24" HD Samsung monitors and a 43" Sony UHD TV, XBR-43X800D. 2, Panasonic DVX-200 Cameras.
    is Quicktime player installed and working?
      Would it be possible to upload a small file that way we can look to see what the exact format is inside the wrapper. Some companies make non standard files.
        What do you mean they are low res? That usually means proxy which would not a sense here.
