1. Is there any tool in Edius that allows one to manipulate the size and angle of an image by moving each corner? In layouter I can stretch or compress the image vertically or horizontally separately, by unticking the 'preserve frame aspect' box. I would like to move each corner on its own.
2. Is there a way to rotate an image more finely? I can rotate to eg 1.10 degrees or 1.20 degrees- but if I try to rotate 1.23 it reverts to 1.2; 1.26 reverts to 1.3 etc.
3. Is there any way to see both the image I'm working on and, eg, a half-mix with another image? I'm trying to get as exact and seamless a match as possible and it would really help if I could see each change as I work, rather than having to save the changes in layouter each time to check the match. (I had a storm card in a previous machine running 5.5, and I'm pretty sure I could do that on the external monitor. But haven't put the card into this machine running Edius 7.)
Thanks!
Thanks!
