Problem with activation key
  • Problem with activation key
    It seems that there are problems with license keys for EDIUS PRO 7.
    It seems also that a "Serial Number replace form exist".
    Is there somebody able to give me the exact procedure to follow ?
    Thank you for your attention.
    Please contact technical support for your region.
    We apologies for any inconvenience.
      Hi- I'm in New Zealand, which doesn't appear to have a region. But I bought the upgrade from B&H (USA). Should I try the USA support?
      Cheers Rob
        In your case it is best to contact you reseller.
          I wonder if B&H can sort (are allowed to) licensing issues?
            If they cannot they will direct the customer to someone who can help. :)
            The issue is that I cannot guarantee that if you purchase out of your region the re-sellers /distributors will honor support for that product.
            Grass Valley tech support is always an option.
              why the company Grass Valley can not create your own website where you can purchase a license edius without any third-party, such as the same Apple or adobe. It is not convenient to buy through a third-party sellers. make the online purchase and the number of purchases will increase.
              Windows 10 x64, Edius 6.55, Edius 8 Pro, Intel 4790K, ASUS Z87-PLUS , DDR 32 Gb, Nvidia GeForce 780 , Apple Cinema Display 27, Canopus NX with Expansion kit
                How is it less convenient buying from a 3rd party? In a lot of cases the 3rd party reseller will also give support which depending on the problem can be quicker and more comprehensive than dealing with GV support.
                  I'll have a go.
                    because it will put resellers out of business
                      I think corsairsolutions.com.au are the distributor for Australia and NZ
                      If you buy from them or their resellers, you will have support
                        After feeling ignored for four days (admittedly over a weekend and some time-shifts) both GV and B&H jumped in. So new serial number and all good so far.
                        Now I'll find out if my old laptop can edit 4k. I think it may be crying quietly in the corner already :)
