how do I mix down audio again?
  • how do I mix down audio again?
    I've done it before, but I forgot!
    I have three channels of audio and all I want to do is export it into a file where it's all mixed down and not a distinct chan 1 and chan 2...make sense? I'm not an audio guy!
    Big thanks.
    dave
    if your project setting is stereo 2 channel, you should get a perfect mix
    by default, EDIUS creates project presets with 7.1 surround sound presets of 8 channels, I hardly use that
    if you shot with wireless mic on left channel and it is located on 1A, it will appear on the left channel only unless you put the panpot filter on that clip and place the pan slider to the middle or modify the channel map by going to sequence settings
