I'm trialing Edius 7 and ran into a problem where the timeline will not scrub, as well as where the entire UI stops responding. I found an old thread (2011) on this, but it didn't have any resolution.
The system is an I7 4970K, 16Gb, NVidia GTX 760 2Gb, with SSDs and fast RAID drives for media. None of the media drives have indexing enabled. This is a dedicated editing system, so no antivirus. The only thing unusual is I have an older NVidia driver (344.75) in order to support my current editor.
The primary problem is that when scrubbing the timeline, the monitor remains frozen on the current frame for 10-20 seconds, then catches up to the timeline position. Sometimes it hangs long enough to go into the unresponsive mode. The timeline and source material is HDV.
It's certainly not a hardware issue. This is a custom built system for editing HD. Is there a known problem with using the older display driver? Or is there some setting somewhere that I should be changing?
