My edius 6.5 locked up - now says unregistered-help!
  • My edius 6.5 locked up - now says unregistered-help!
    Hi all,
    My 6.5 has been rock solid since the day I bought it. But today, in the middle of an edit it locked up- I had just removed a little clip from the timeline. So I rebooted and it is now telling me that my version is unregistered , so register or start in trial mode. This has never happened before and I am stuck big time!
    What should I do to get going again? would restoring the computer (win 7) to an earlier time help or is this just an Edius problem? I have a big project on and I don't want to lose today's work or fail on the deadline.
    thanks in advance.
    Rod
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    what happens when you click register and enter your serial? or do you already have it activated on 3 computers?
    before you do, make sure the license manager is present in taskbar and has not been killed by an antivirus update
      Hi Anton,
      It is only on one computer and has been transferred about a year ago to my current win7 pc from an earlier pc, so maximum 2 loads I would guess.
      I haven't attempted to enter in the registration number yet- wasn't sure if this was the right thing to do. any thoughts?
      Rod Pike
        hi again Anton, I have just checked my grass valley registrations and it is showing there as a registered software (2012). I did a search for license manager and it came up but there is nothing in it.
        Rod
        Rod Pike
          Rod
          there is no need to search for license manager, it must always be on the taskbar
            I see. It isn't there, so although I can call it up in a search I can't find it on the list of programs in win7 control panel. How do I get it on to the task bar and should I enter the serial number in the activation box? my concern is that as GV show my registration details OK it may not let me enter the number again.
            Thanks for your help.
            Rod
            Rod Pike
              Sorry Anton, it is there! (must get new specs!) so what would you suggest I do next please?
              Rod
              Rod Pike
                Rod
                right click it and then click license list, then provide screenshot
                  Rod
                  If license manager is not in the taskbar
                  Go to start<>Run and type "Msconfig.exe and go to the "Start" tab and check it is set to start with the computer
                  See attached
                  Barry
                    Thanks Anton, when I print scrn all I can save is the background, it doesn,t save the License list box- but there is nothing in it anyway. I am feeling quite stupid at the moment, not knowing how to do this! (should I just enter the code and see what happens? but I don't want to use up a registration just for it to fail.)
                    Rod
                    Rod Pike
                      Here it is Anton. ( I hope1)
                      Rod Pike
                        and here is my startup screen Barry &Anton.
                        Rod Pike
                          Rod
                          I don't see GV licence manager there
                          Is it showing in the disabled area? as per my picture?
                          AND
                          My startup does not have your Edius Entry, maybe difference between 6.5 and 7?
                          Regards Barry
                            Barry, isn't it the last line? it says GVLICe.
                            that is everything on my startup screen and nothing is disabled. And the licence manager, although blank, is on my task bar. Any further thoughts Barry or Anton? - should I just put the registration number in? (although my Grass valley account already shows it as registered.)
                            Rod Pike
                              Yes Rod
                              I added a Queri re that, I cannot remember the difference between 6.5 and 7
                              If it appears in the taskbar then it should be OK, but why did the registration disappear in the first place? Thats a worry
                              I run Edius also on my laptop and recently had only one rego left and then the HD on the main computer died and had no choice but to use it
                              After talking to my local reps I am confident if I had a need to reregister there would not be a problem, but, it is still a worry
                              Regards Barry
