I filmed and edit my film in 25 frame but i need to convert it into a 24 frame uncompressed AVI for further process, can I do this with Edius?
24 frame vs 25 frame
Edit your feature in Edius & export it as usual at 25p.
After that create a 24p project at same resolution & with same audio setup.
Drag the exported 25p based AVI to the BIN & open file properties (alt + enter). Now change frame rate to 24p & field dominance to
progressiv if Edius sees interlaced. Now drag the file from BIN to
timeline. Audio will stay perfectly in sync. The whole movie gets
4,166666 % longer due to the slow down process.
In general, if you film for a cinema release it is the better way to do
this at 24p. Its because the audience is more tolerant to a movie
that got speed up (24 -> 25 for DVD release) than the other way
around (25 -> 24 for cinema releases).
AndreasAndreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Standards
Originally posted by henry poon View PostI filmed and edit my film in 25 frame but i need to convert it into a 24 frame uncompressed AVI for further process, can I do this with Edius?
It was the case in EDIUS 6, and I was hoping thing get better in EDIUS 7, but it's still the same. It's hard to understand why there isn't a HD720 25p BlueRay format...
What i really terrible is the inability to change the frame rate of an existing project. Neither can you import sequences from a project with a different frame rate. I ended up with converting projects to Full HD (upscaling), but that extends the encoding time and wastes capacity on the media without improving anything.
Also the method to encode/export each sequence in the original project to a file, just to import it in another project seems unnecessary complicated and not flexible (if you want to change something in the sequence).
And if you have horizonal camaera movement, all interlaced formats are an absolute no-no, because the result just looks terrible.
I wondered: Could I "hack" the project XML file to change the frame rate, so Edius believes the project has the correct frame rate for BlueRay?
Of course I'd prefer if I could change the framerate right inside an EDIUS project, even if I loose all pre-rendered parts and most marks would move by one frame. Many cheaper products don't ask for a frame rate before you actually encode your project. I'd wish EDIUS could be smarter, too.
What he want is maybe possible with NLEs that provide support for multi sequence projects of different frame rate.
AndreasAndreas Gumm
Windows 7 Ultimate,
PC 2
Will Edius allow conversion between the frame rates?www.skysimonephotography.com
www.skysimonefilm.com
www.facebook.com/skysimonephoto
Laptop:
ASUS - 17.3" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1050 - 1TB Hard Drive + 256GB SSD - Metal Star Gray
Edius Pro 9 Windows 10
Originally posted by Steady Hand View PostLiving in Germany (were we have PAL (and 50Hz), not NTSC), most cameras (once set to PAL) record with 25fps, so it's very natural you select a 25p format for your project. However, if you want to burn your HD720 25p project to BlueRay, EDIUS refuses (as you can only burn 24p for HD720).
.Main Editor - Edius 8.53 AdobeCC Mini Monitor 4K Intel X99P SLI Intel Core i7 6800K CPU Gigabyte GTX980 SanDisk Ultra Video SSD 1XINTEL System SSD 16GB Kingston DDR4 2400 RAM VisTitle 2.8 Onboard Sound 10GBE LAN WIN10Pro 64bit
www.nakedeyedv.com
