Effect For Bald Spot
  • Effect For Bald Spot
    What type of effect would you use for a bald spot?
    http://screencast.com/t/nRFhJhdra64e
    I have the full NewBlueFX package.
    Would depend on what result the client wants; could range from reduce the glare to full head of hair.
      IF you are serious, then you need to track the head in AE or Nuke or better yet, Resolve which is free, and then create some hair or copy the existing pate, should be fun!
      er, heads up?
      Paul :-)
        you can draw a mask with soft edge, outside opacity 0
        duplicate clip to track above
        drag mask to clip above
        use layouter to move clip up so that hair from below fills the bald spot
          Nothing in post can replace an on-set stylist.
          Worth their weight in client happiness.
