This post is more for getting some hints and tips on possible configuration and settings to make Edius run better than actually saying there is any problem.
The set up is this, Place a number of 720p clips on the time line along with a number of SD clips (SD clips on track above HD clips). Total time of most clips 25 minutes or so and there is a total of 3+ hours on the time line.
System specs you can see below and I am running the last update of Edius, 7.50.
So actually as soon as I import clips into the bin the hard drive takes off and I know it is indexing the video and also reading the audio tracks for the waveform and possibly other functions. This is the issue, if I then say need to video mute or audio mute some of the tracks, there is a huge delay in response while the system is doing whatever it is to or for the new clips I have pulled in. Scrubbing and normal play back seem to be ok once I get control back but even cutting a clip has a big delay.
While I think I understand what is going on in the background, (and if I am incorrect , please inform me), what can be done set up or settings wise to eliminate or minimize the issue? (other than to walk away and get some coffee)
Thanks,
Jeff
Thanks,
Jeff
