From .mp4 to blu-ray: help!
  • From .mp4 to blu-ray: help!
    Hi, I have 12 .mp4 video with different codecs on Edius 7 timeline (around 4 hours and 30 minutes). Now I have to burn a blu-ray. I have made a try and Edius needs to work around 11 hours. Afer 10 working hours Edius gave me an ERROR and it was impossible to burn the blu-ray. Will I need to begin again or it is better I convert those .mp4 files separately and then to put them on the timeline?
    What can I do please?
    CPU: Intel i9 7940X
    SSD Drive:
    Do you have another authoring package that you can try? That way you can encode your clips and then bring them into the authoring program.
    When you use avc to encode, you will need Quick Sync or a lot of cores to reduce encoding time.
    Can you use Mpeg2 as your encode codec for the bluray?
    This might not be possible due to the total time of the project.
    If you don't have a secondary authoring program you can try rendering the entire project and then try to make the disc again.
    Just create an image and then burn the image with Imgburn.
    You could also download TMPGE TAW 5 trial and try it for free for 14 days. Just export your videos to HQ or HQX and import into TAW.
    It will encode them to Blu-ray standards.http://tmpgenc.pegasys-inc.com/en/product/taw5.html If you do a lot of discs, the $99 price tag is well worth it.
      I have made the rendering and then I was abled to burn the blu-ray. Thanks
      CPU: Intel i9 7940X
      SSD Drive:
        I sould look into a separate authoring program.
