You want to move an item in layouter- you can do it manually and constrain the axis with the shift key or you can adjust the values with the thumb wheel. Is there a way of using the arrow keys (like you can in Photoshop and similar) ?
Nudging in Layouter
I don't know if this is what you want, but if you click on the position axis that you want to adjust, and instead of using the scroll wheel to change the values, just use the up or down arrow key. Any item with a value can be adjusted this same way.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
Originally posted by DigitalDave View PostWhat I want to do is nudge the item with the arrows without going to the values, just as I would in Photoshop.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
IT maybe because there is no SMPTE standard for 50P timecode.
So I think MC handles it by using 25P and pairing frames.
Look at the timecode and you may see it count in 25 not 50.
I think this is so you have compatability with 25fps systems.
