Another reset problem with 7.5?
  • Another reset problem with 7.5?
    After upgrading to 7.5 I seem to be having a problem with Burn to Disc resetting itself to x4 on the disc speed every time I use it.
    (I'm using x16 discs that I always use).
    As I'm doing over 100 one dance type DVDs this is very annoying!
    Yes, I also have the Insert/Overwrite button reset problem.
    Can someone else try this also please to confirm?
    Cheers,,
    Vaughan
    all I can say about this is to avoid burning with EDIUS, instead compile to folder and then burn the AUDIO_TS VIDEO_TS the correct way
    Using Imgburn (free software) to burn a DVD using a single layer DVD-R
    or use Nero Burning Rom and choose the DVD_Video template
      Thanks Anton, but I'd still like to know if anyone else can duplicate this so it can be reported as a bug. After all, all I'm doing is sticking one dance routine on the timeline, title it, fix audio levels, then burn it to disc: repeat 120 times. I don't need to go outside of Edius to do this.
      Cheers,
      Vaughan
        Where is your burn temp folder located? Move it to the largest drive on your system.
