I notice my MTS files are top field first when I bring them into Edius 5.51. I thought I read here files should be bottom field first to edit. Also if I convert them to AVI that also indicates top field first. Should I have changed the MTS files before converting them? If I edit using the MTS files, should that remain at top field first or should that be changed to bottom field first? What problems arise if this is not set correctly?
Top Field or Bottom Field First
Edius 7.5. Windows 7 Home Premium 64Bit. Nvidia G Force 9400GT - 1 GB Video Memory. 8GB RAM. Direct X10. Intel CPU-DP35DP-Quad Core Intel64Family6Model23 Stepping10(2009build). Max Clock Speed 2666MHz. 1-240GB Sandisk SSD UltraII. 1-1TB - Seagate HardDrive ST310000333AS ATA. 1-2TB Seagate HD STBD2000101. 2-Panasonic AG HMC150 cameras.Tags: None -
Leave MTS and TFF if editing HD.1: Intel 13900K, Asus ROG Z790 Hero, G. Skill Trident Z5 6400 64G DDR5, Asus Tuff Gaming GeForce 4070Ti, WD SN850XNVMe 1T, 4T (2), Seagate IronWolf NAS 7200 14TB, Lian Li Galahad 360, Aja Kona 4, Super Flower Leadex Platinum 1600W
2: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200 -
bottom field first applies to DV only, all other formats are upper fieldAnton Strauss
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 64GB DDR4 Ram, Win10 ProComment
TFF or BFF
Thanks to all for the replies. This assignment was edited in DV 16x9 because the final product will be a quantity of DVD's. So now I have a better grasp of TFF and BFF; I will use TFF if editing in HD. I had adjusted the settings of the AVI files to BFF before editing - did I need to do that or would the program have done it automatically for me? Do I get better quality if I edit in HD then burn the DVD's? Or is it the same quality if I just edit in DV 16x9 and burn DVD from that?Edius 7.5. Windows 7 Home Premium 64Bit. Nvidia G Force 9400GT - 1 GB Video Memory. 8GB RAM. Direct X10. Intel CPU-DP35DP-Quad Core Intel64Family6Model23 Stepping10(2009build). Max Clock Speed 2666MHz. 1-240GB Sandisk SSD UltraII. 1-1TB - Seagate HardDrive ST310000333AS ATA. 1-2TB Seagate HD STBD2000101. 2-Panasonic AG HMC150 cameras.Comment
