Need help with a keyboard shortcut
  • Need help with a keyboard shortcut
    On my old editing computer I used a keyboard shortcut (the underscore or hyphen key) to toggle between the timeline "Mixer" which on my new system is alt + W. I don't see this option in user settings / keyboard shortcuts. Any ideas if / how I can change it? I'd rather use the one key versus two (plus I've been doing it this way for years).
    David
    DMS Films, New York
    Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.com
    Go to the keyboard assignments and go down to "Toggle Audio Mixer Display"
    Hope that helps
    Regards Barry
      Barry thanks for the help. I'm trying to accomplish something else. Maybe I didn't do a good job of explaining. If you look at any video track on the timeline there is a number, a "V" and then an arrow beneath. If you roll over the arrow it gives you the set keyboard shortcut of "Mixer" (Alt + W). I set the same function on my old system (5.5) using the hyphen key. I can't seem to do it on 7.2. I would like to hit one key and then the Video track toggles between opening (where you can click "mix" and activate keyframes) and collapsing the Video track. Ideas?
      David
      DMS Films, New York
        Sorry David
        Mind out of gear
        Go to Keyboard settings and select "TRACK" in the Category
        Go to "Extend Mixer Track display"
        Hope I got it right this time
        Regards Barry
          Just got back to editing… thanks Barry. That's just what I was looking for. Cheers!
          David
          DMS Films, New York
