No Audio Playback Edius 7
    if you are on win_8.1 ... you can look here for a solution ....
    have help in 3 cases on the german Edius-corner
    and now ditto here in "Vancouver, B.C"
    http://forum.grassvalley.com/forum/s...218#post247218
    Hans
      yes, some antivirus programs are still trouble even when disabled
      I don't use any protection at all on the Edit PC
        I've uploaded two more screenshots with audio showing in the meters. I created a new project with the color bars, but still no audio, with or without the HDMI plugged in.
        Hermit's Lair Media Productions LLC
        Desktop: Edius 8.3 Intel Core i7 / i7-4790 Windows 10 / 32GB DDR3 SDRAM, CineRAID w/ 4 4TB HDD's @ RAID5
        Laptop: Edius 8.3 / ALIENWARE 17 - Intel i7-4910MQ Processor 2.9GHz 32GB Dual Channel DDR3L at 1600MHz RAM, 2TB RAID 0 5400RPM + 80GB mSATA SSD Caching, Windows 7 Ultimate (64-bit) 17.3" WLED FHD , 8GB NVIDIA GeForce GTX 880M Graphics
        "Those who danced were thought to be quite insane by those who could not hear the music"~John Milton
          Here's one more screenshot
            In addition, when I go to System settings - Preview Device, when I click on the 'settings' button I get the message 'Device doesn't support the current format - Unable to update settings"
            • #21
              I checked out the link to the page Hans suggested... I then downloaded the DirectX End-User Runtime Web Installer and ran it, reopened Edius, and now I have audio. Whatever the DirectX thing did, it solved the problem... thanks again for all the help on this forum.
              • #22
                also, you may want to fix your project setting, you have it set to 8 channel audio (makes no sense), set it to 2 channel stereo, unless you are planning to make 7.1 surround sound
                • #23
                  When you installed Edius did you see the DirectX tickbox? If you didn't check the tickbox that would more than likely be why the Directx download fixed your issue.
                  • #24
                    the EDIUS installer should tick that automatically if it detects that directx is missing, just like it does when Quicktime is missing, so I would call this an EDIUS bug
                    • #25
                      Hans
                      Thanks for Hans and this threat
