With 12 cores it looks like the system is utilizing only 8% of what the CPU can crunch. I am running the test version of Edius 7.41. Will activating the version speed things up?
multi-cores transcoding HQX to PorRes is supper slow
Activating will do nothing different.1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
If you are going HQX to PRORES then it will be your PRORES codec which will be slow. Are you using the Maraison codec? Also almost anything using Quick Time on windows will be slower in general. Edius is not slow at encoding overall.
Best
DaveMain Editor - Edius 8.53 AdobeCC Mini Monitor 4K Intel X99P SLI Intel Core i7 6800K CPU Gigabyte GTX980 SanDisk Ultra Video SSD 1XINTEL System SSD 16GB Kingston DDR4 2400 RAM VisTitle 2.8 Onboard Sound 10GBE LAN WIN10Pro 64bit
www.nakedeyedv.com
Yes - I am using the Maraison ProRes codec.
I am not 100% convinced that the codec is the bottleneck. I will have to test this by going straight from HQX to HQX. If the CPU is still hovering around 8% and the HDD are also still showing 18% usage at about 7MB/s, then it is clear that Edius is only using, and maybe only "seeing" one core!
Is it time to go virtual, to use my 12 cores?Edius X is what I use here at FilmFix for editing and color grading our high quality 2K film transfers of 8mm and Super-8 film.
HQX QuickTime export is native since Edius version 7.4 & not compareable to Apples QuicTime engine!
AndreasLast edited by Andreas_Gumm; 12-18-2014, 09:23 PM.Andreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
So I made the test, and Edius got the CPU up to 92% and the HDD data 200MB/s. It must be the ProRes codec, or the QuickTime envelope that is not supporting multicore processing.
So I did one more test, QuickTime envelope with HQX codec, and see -- see, the CPU is at 89% and the HDD data 188MB/s.
Checking the Miraizon version I discovered I am running v. 1.0.2.1. I will recheck after updating to v2.Edius X is what I use here at FilmFix for editing and color grading our high quality 2K film transfers of 8mm and Super-8 film.
Originally posted by More4K View PostWhat speed are you getting?Edius X is what I use here at FilmFix for editing and color grading our high quality 2K film transfers of 8mm and Super-8 film.
