Problems with auto save
  • Problems with auto save
    Although I auto save very frequently , after a computer crash I cannot find the last saved edited project sequence. I can locate the saved project file which is about 15 kb BUT the edited sequence is what I cannot find.
    I thought that AUTO SAVE was suppose to reopen the latest edited sequence.
    There should be a series of files in the following folder
    Your Hard drive>Edius>your project name>project>backup>your project name+++++.ezp
    These are read-only files.
    This applies to Edius6v5
    Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
    Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
      Auto save saves the project. The project can have many sequences. If it does not open with the correct sequence you need to find it in the bin and open it.
        Thanks guys but it seems as though EDIUS is just saving the PROJECT FOLDER which is a small file Approx : 15 kb instead of saving the last edited sequence when Ctrl + S is pressed. I hate to mention this but there is another NLE that has an "attic " wherein the latest edited sequence can be retrieved just in case there is a catastrophe.
          EDIUS only ever saves the whole project. Not individual bins or sequences like Avid. Its equivalent of the attic is the back up and autosave folders which are wherever you made the project. The backup folder has a backup made when ever you press save. The auto saves are made automatically at a time specified in the preferences.
          Where did you specify the project should be when you started EDIUS? Have you looked there?
          The file you say says its a project folder, what is the extension? Maybe post a screen shot so we can explain where you are going wrong. EDISU projects have a file extension of ezp and windows says they are EDIUS projects as per the attached picture.
            Let me add to what David said. Not only does Edius save all your sequences, bins, etc. in the EZP file, but you can tell Edius how many backup EZP files to save and you can even tell Edius to save an extra copy on another drive. See the attached screenshot of the user settings dialog box where this is set. It is almost impossible to lose your work with Edius if it is configured correctly. As good if not better than "The Attic" from that other NLE.
            My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
              Thanks guys . . it's working , your help greatly appreciated as usual.
