Hello, I am trying to burn a dvd like I have always done and I receive "the parameter is incorrect" messege. Any ideas on what may be the cause? I have tried burning the dvd in dvd drive as well as in the bluray drive and it appears both times. I am burning from an usb3 external drive which as worked many times before. I am also trying to burn directly from my timeline which I like to do.
the parameter is incorrect HELP
I just tried burning a sequence from a timeline I have had success with before both bluray and dvd versions...no luck. This sequence is also on my internal drive, so I think I can rule out the external usb as the problem. I am currently trying to burn the old once successful sequence onto a bluray. We will see if this works.
Okay, I successfully burned a bluray both from the current project I was trying to initially burn a dvd from. I also was able to burn a bluray from a file from both external drive usb3 as well as one on the internal drive. I tried burning the dvd using the bluray drive but same error came up. What could be wrong?
need to see a screenshot of projects settings with advanced expanded (for some strange reason advanced often opens collapsed as if to prevent people from seeing advanced, it is beyond me why it should be hidden)Anton Strauss
Well the project is HD, that is why you can't burn a DVD and why you get that message.
You can burn a Blu-ray or convert that project to SD and then burn a DVD.
You can do this using Anton's guide here:
Last edited by John Hooper; 12-07-2014, 06:28 PM.Edius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 Monitor
Originally posted by jeff8 View PostHere is the screen shot
[ATTACH]12358[/ATTACH]
however, these settings should be fine for DVD export, what exact version of EDIUS are you using?
if 6.5 or 7, I would switch to SD and enable Lanczos3 prior to DVD export, then when done, switch back to HDAnton Strauss
I am using edius neo 3.5 and have been successful many times with these settings for dvd and bluray. I actually chose this setup just in case a client changes their mind wanting either dvd or bluray. How would i change it to sd? I thought choosing upper filed allow for sd export?
I already have an SD preset premade in system settings, so I go to project settings and simply click the SD presetAttached FilesAnton Strauss
and if you don't have a premade preset, simply change the current one from 1920x1080 to 720x480 and set Lanczos3Anton Strauss
