I'm early in my transition from 5.5 to 7.4. I copied all of my title presets from Quick Titler that were created in 5.5. Most of my titles are simple and typically use Trajan Pro which is a popular movie-stye font. I can open all the presets in 7.4 but Trajan Pro isn't there anymore. Is there a way to load TP into 7.4? I started looking at other fonts as well. Are there any other similar fonts anyone would recommend?
Fonts in Edius 7.4 Quick Titler
David
DMS Films, New York
Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.comTags: None
is the font installed and available in other software?Anton Strauss
Not sure. But it's in 5.5. Can I somehow export from 5.5 and then import into 7.4?David
DMS Films, New York
is 5.5 on the same PC as 7.4????
if not, simply go to Windows/Fonts in 5.5 PC and copy the font and paste it to a USB, then insert the USB on 7.4PC and right click the font and choose install, or simply paste to Windows/Fonts and then rebootAnton Strauss
When you went from 5.5 to 7 did you also upgrade your operating system?
Quicktitler uses the Fonts installed on the computer
Sorry Anton beat me
BarryWin 10HP, EDIUS WG9.4, HD Spark, Boris RED 5, VMW6, Authorworks 6, Bluff Titler, VisTitler 2.8, NEAT 3/4, Mercalli 2/4, Vitascene, Izotope RX6 Plugin, NewBlue, Trend Micro AV
Two different computers (see my signature below). 5.5 is on Vista and 7.4 is on Windows 8.1. I'll give your suggestion a try. Thanks Anton and Barry.
Update: Success! That was a lot easier than I thought. Cheers.Last edited by DMS Video; 12-03-2014, 06:35 AM.David
DMS Films, New York
