Where and when to use 16X9
    I got a good one, I had to resixe some assets in my timeline to match my video. I use Scenalyzer to capture. The only catch seems to be I need to set my DVD player on 16X9. I hope the clients have that piece of mind. And the compression which I cant do much about until I go HD.
    Randy
    Randy
      I always put a note on the jewell case label "If your video fails to display correct size, check your DVD player and TV to make sure they have the proper settings."
        oh crud!
        oh well I did all the 16X9 encoding and got it looking really good just to find that DVDSP 4 doesnt support 16X9 in 720X480. Everything looks great with the exception of the transistions a on the chapters which switch to 4:3 when I hit a chapter. Oh well im learning.
        Randy
          16:9 DVD IS 720x480. The difference between 4:3 and 16:9 is the flag on the MPEG2 clip. I don't think you're getting this.
          Just shoot in 16:9, edit in 16:9 (note, if you use Xplode Pro, some transitions don't support 16:9 so be careful) then encode to 16:9 MPEG2, and finally author in a 16:9 project in DVDSP4.
            Where and when to do 16X9
            How do I change my project setting in DVDSP 4, when I went in the manual it had a chart and it said under 720X480 that only 4:3 was supported.
            Randy
            • #21
              I don't use DVDSP much, and right now the computer is rendering to MPEG2 through Windows out of Edius, but I will take a look at DVDSP and give you an answer tomorrow probably.
              It "should" be in the menu inspector, but I am not really eligible to answer this without looking because I don't use DVDSP, so I would be able to find the answer through trial & error, unless someone already knows the answer.
              Either way you should know that a true 16:9 disc will fill the whole screen when playing to a wide TV, and a wide disc will show it letterboxed on a 4:3 TV. There shouldn't be any bars on a wide screen TV.
              • #22
                Yeah, I got that part. If my DVD player is set to 16X9 it does fill the screen. BUT in DVDSP 4 I cant find a 16X9 project so if I use transistions for chapters and menus there 4:3 then it switcheds back to 16X9
                Randy
                • #23
                  Ok Randy, I found out how to do it. You need to go into the inspector and under the "Menu" tab, select "16:9 Letterbox" from the default Display mode. The transitions should be ok now....unless this is what you've been doing all along. I will look deeper into it...but I do recommend that you read the manual more thoroughly. You can make the default 16:9 by going into the preferences then general then under display mode choose 16:9 letterbox.
                  • #24
                    Thanks Dave, In my own defense I did read the manual(which is rare) thats where I got the thing about only 4:3 being supported in 720X480.
                    Randy
                    Randy
