Has anybody figured a way to correct for overscan reminants with the SMPTE effects within Edius? I just noticed a couple when a widescreen project played on a computer and a 4x3 letterboxed version. I think I can fix it but, I don't like what I will have to do.
NTSC effects in Edius
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9, Apple 30", Samsung 24", dual BD.Tags: None
Originally posted by STORMDAVE View PostYeah I asked about this a while ago, you can disable overscan individually but not globally. If you use xplode (pro or for edius) you can disable overscan globally.Jerry
Jerry ,
I have to look for my documents on this but I think that the smpte transition rule determents an overscan. If I am not wrong there is no 0.
That why on 1080 you still have 16 pixels as over scan. I have to look it up. To many things to remember.Steve
Since there isn't an option panel to adjust settings, I kinda think that it stays that way. For playback in letterbox mode and on a computer, the effect is noticeable....probably more to editors than to viewers.
I was thinking that the effect has to have settings somewhere on the system. If those can be accessed and changed....
By the way, thanks for looking Steve.Jerry
That's what we are here for. But I am going to give you a better answer if I can fin those pesky documents.
heheSteve
Originally posted by SRsupport View PostThat's what we are here for. But I am going to give you a better answer if I can fin those pesky documents.
heheJerry
hmm, I thought setting edius overscan to 0 should fix this, did you try that?Anton Strauss
Originally posted by antonsvideo View Posthmm, I thought setting edius overscan to 0 should fix this, did you try that?
Where do I find that setting ? I remember seeing that panel but can't find it now.Jerry
When you go in to project settings it is default at 3 put it to 0Steve
Originally posted by SRsupport View PostWhen you go in to project settings it is default at 3 put it to 0
Thanks Anton and Steve. That solved the problem and as far as I can tell it didn't affect the other transitions or video. That wasn't the panel I was refering to. I think it used to be in the applications settings at one time.
I may be wrong on that.
So if you intend to use any of those SMPTE wipes, or page curls...make sure to chage the overscan from 3% to 0%.
I haven't used these effects much do to the overscan 'issue' and no apparent adjustment for it.
By the way, these are also rt for you RT guys.
Thanks again.Jerry
my overscan is set to 0% 365 days per year
it was only usable during the old analogue days, where you could hide the black blanking frame during a transition and the TV sets were hiding the overscan area, so you would never see the left behind frame during the transition
now that people use media players and LCD and Plasma, 0% overscan is the goAnton Strauss
Originally posted by antonsvideo View Postmy overscan is set to 0% 365 days per year
3% is great if the product is 16x9 and played on a 16x9 set. When it goes to computer or 4x3 letterboxed all bets are off.
So, 0% is the new default setting. At least now I have a whole lot more effects from which to choose.
Once again thanks!Jerry
