Hi
I suspect that I'm missing something obvious, but since I upgraded from Edius 5.1 to 7.4 the audio levels seem to have gone haywire. As an example, in Edius 5.1, when recording a VO with the mic level peaking at 0dB max, the waveform on the audio track was at an amplitude that was easy to see and adjust with the rubber band if necessary, and gave an output level on the status overlay also peaking at 0dB max.
Now that I'm using Edius 7.4 I find that when I record a VO at 0dB max as before, the waveform on the audio track still looks about the same amplitude, but the VU playback level is at least 12dB high. If I normalize it to -20dB, the playback level on the status overlay looks OK, but the amplitude of the waveform on the audio track is so small it is hardly visible. The audio mixer has all its track faders and Master set to 0dB and in the Off mode. The rubber band level is also 0dB.
Similarly, if I rip a track off a CD and lay it onto an audio track in Edius 7.4, the waveform looks OK, but in the Audio Mixer the track level and the Master level are both at least 12dB high. Am I missing something, surely this cannot be normal.
In Project Settings the Audio reference level is always set to -20dB.
OK, I've found that if I monitor the levels using the Peak meter, the output level matches the input level, but using the VU meter shows the more than 12dB overload. Why is this? and what meter should I use for correct recording levels?
