I am trying to see the key function in the 3 way colour corrector.
I have applied a mask using the "mask video effect" to a section of video.
I then on the "inside" tab and select 3 way colour correction filter.
I then double click the filter to set it up.
When i go to select the mask display button nothing happens.
The Histogram button works.
If I apply the 3 way directly to the clip I can get a mask.
Buy I need to change colour of just a section of the clip, hence using the mask tool.
I have made sure the User settings/playback/combine filter layers is ticked.
Also I thought it was realtime, if I adjust the colours I cannot see anything happening, but if i alter the colours and click okay and return to timeline I can see the adjustments.
What am I doing wrong?
M
M
