Hi,
I have just assembled a new PC but I had many problems with videocard.
It was a SAPPHIRE RADEON X1950XT 256MB GDDR3.
The technican did a test. It has just replaced that videocard with a simple Nvidia GeForce 6600 GT. Now Edius 4 works very fine and everything is ok.
Perhaps was my old videocard broken or is it a bad videocard with Edius NX?
I'd like to get a new SAPPHIRE RADEON X1950XT 256MB GDDR3 videocard but I am worried. Can you tell me if that Ati videocard works fine with Edius NX and Edius 4?
Thanks a lot.
This is my config:
Scheda Madre: P5W HD DELUXE
MICROP. CONROE E6600 2,40GHz FSB 1066 4MB cache LGA775
Videocard: SAPPHIRE RADEON X1950XT 256MB GDDR3
ALIM: ENERMAX INFINITY 620W
VENTOLA ARCTIC COOLING 12Vdc 120x120x25mm TACHIMETRICA
VENTOLA ARCTIC COOLING FREEZER 7 PRO X P4 SOCKET 775
Case full tower Cooler Master CM Stacker case
Thanks a lot.
This is my config:
