Avoid track splitting
  • Avoid track splitting
    Hi,
    there's an annoying special key in Edius (I guess "ò" or "@") which, if accidentally hit, breaks the link between the video and audio tracks in the viewer. How can I re-sync the tracks? It keeps them separated even if I reboot the program, the only way I found to fix it is to re-import the clip.
    You can try hitting X. Or simply grab it from the Bin and reload it in the Player monitor.
      Ok thank you hitting X seems to work.
      However, the key was "U"
        Is U the same as ALT G?
        Theo
          U is generally set audio in point
