I am using the layout error to do some Ken Burn Movement FOR pictures. I set the key frames at both the end and beginning of the pictures. Once I add a dissolve I get extra space which I then need to go back into layout and move the key frames a tad left at the beginning of clip and a tad to the right for the end of the clip. Is there an easier way to do this. I want a continuous motion between the pics as the dissolve into one another. Thanks in advance.
Layout error key frame question
Have you tried un-checking the "Extend Clips when applying Transition/Crossfade" in the User Settings, before adding the dissolve?Attached FilesEdius 8.53WG, Vistitle 2.8, Windows 10 x64 Pro Fall Update, Asus Z87 Pro, Intel i7-4770K, 16 GB 1600 Corsair Vengence LP RAM, Samsung 840 Pro SSD 256GB, WD Black 2TB media drive, Intel HD 4600 GPU, MSI GTX660 2GB VGA, Coolermaster Silencio 652 case, Noctua NH-U12S CPU cooler, Cakewalk UA-25EX USB audio interface, Cakewalk MA-15D monitor speakers, BM Intensity Pro 4K, PlextorPX-LB950SA BD writer, Dell U2410 Monitor
