Can somebody help me with the specs for graphics cards that is compatiable with dv storm capturing card?
Graphics card specs
this would mostly depend on the version of Edius you useAnton Strauss
edius pro 3.6 is great software
most graphics cards should work, depending on PC, geforce (Nvidia) would be my choice
if your PC has an AGP slot, then I can recommend a driver version for realtime Xplode transitionsAnton Strauss
Anton which version is that? Is it available to download from nvidia's website?Aristotelis Bafaloukos
BEng (Hons), MSc, MBCS
Ctrl+Alt+Delete
yes, you will find it in archives, I use version 61.77 (driver download area appears to be down)Anton Strauss
what are your overlay settings in Edius 3.6? try some of the many possible combinations, one will work
http://www.videoproductions.com.au/e...y-settings.gif
be sure to restart Edius after each overlay changeAnton Strauss
