titlemotion pro on edius 4.5 problem
  • titlemotion pro on edius 4.5 problem
    hi guys
    I wana install titlemotion pro on edius 4.5 but it can not find my edius and does not install.
    thank you for your help
    Considering that v4.5 is not yet available, I think you must have a previous version (e.g. v4.24).
    Can you please confirm which version you so that we can help you?
      If it's a TMPro disk from 3.x then it's not going to work with 4.x. The installer doesn't find it.
        I have the same problem could someone help us
          I got the solution. You need to install Titlemotion Pro36 and it shall work perfectly
            Originally posted by ehssanehs
            hi guys
            You should try follow steps:
            1. Uninstall EDIUS 4.5
            2. Install EDIUS 4.02 & "Title Motion"
            3. Uninstall EDIUS 4.02 but no "Title Motion"
            4. Install EDIUS 4.5 again
            Thats all
            But you can update EIDUS 4.6 for using, I think EDIUS 4.6 runs faster than EDIUS 4.5. And Multi Cam is very good
              reply me
              [email protected]
