edius 7 timeline play/stop problem
  • edius 7 timeline play/stop problem
    hi, I am I think old user with edius and I start with edius 3.
    Now I upgrade to 7 pro and have this problem.
    My work its a webtv news and I have to cut interviews, and the problem its that , when I stop the play in time line ( with spacebar ) my cusror in timeline sometimes stops a few frames foward after I press space or other times stops 1 or 2 secondes after. I format my system with a win8 64 , with 16 ram and a Asus P8Z68 Deuxe , and a gtx 770 , please help me
    Ruy Mesquita
    windows 10 64bit latest version
    motherboard asus prime X370 Pro
    processor AMD Ryzen 7 1700x eight core
    32 GB Ram
    graphic card Msi GTX 1070 Aero
    tvamadora.pt
    This is a problem that has been around for some time
      For too long:
        basically, the max buffer size in EDIUS3 was 32, as a result, playback stopped almost instantly
        with later versions, the minimum is 128 and this buffer is unloaded when you press stop, causing a visual jump
        the larger the buffer, the more noticeable the jump can be
          I've noticed that the difference in the delay is associated with the type of video card witch is used.With OHCI or BlackMagic Design is much bigger than with tested Edius Storm 3G.
          I tested in a way to put the cursor at the beginning of the timeline and to press play and stop as fast as possible.With OHCI and BMD what I got was 4-5 frames but with Storm 3G Elite I've got 1 frame witch is result I needed.
          Edius Silver Status
          Gigabyte UD5 X58, i7 950 , 2TB RAID 0,GTX 285 PCIe, 6GB RAM DDR3 1600MHz, OS drive SSD Corsair, 750W PS,Samsung 1920x1080 LCD, GVG HD Storm 3G, Edius 7.30, Windows 7 64bit Ultimate)
          JVC DT-V20L3 20" HD-SDI broadcast monitor, multiformat
            One of the things why I will never ever call Edius a professional program...
              Zzzzzzzzzzzzzzzzzz...
              Andreas Gumm
              post production / authoring
              Windows 7 Ultimate,
              GV hardware: 3G Storm
              PC 2
              GV hardware: HD SPARK
