Using Edius 3.6. and it keeps crashing repeatedly. Soemtimes I know it's about to crash because I'll hear the hard drive make a mild crackling sound; other times it makes no noise.
I've saved my project under a different name as a safety net, cleaned up the project bin, everything is rendered, etc. Is there a way to "repair" the program and avoid uninstall/reinstall? I did purchase the upgrade to 4.5, but want to finish this project before I install it since I'm under deadline. I read thru one other post on 3.6 crashing and Anton replied to check the event viewer for error logs, check disk speed, etc. I did both of those. I have some error logs. What do I do with that information? What is a good/bad disk speed report?
Susan
Susan
